MVP851 stuck in standby
Those KEYIN0, 1, 2 inputs to that microcontroller should be pulled up to 3.3VDC (NS3.3VD, at th VDD pin to the micro) b R5, 6, 7. The pushbuttons connect the circuit to ground. When a pushbutton is depressed, the KEYIN inputs get pulled down to a voltage the is the result of the voltage divider formed by the combination of R5, 6, or 7 and whichever series resistors are being shorted to ground by the pushbuttons depression. The micro senses and interprets the voltage at KEYIN to determine which key is depressed.
If no switches are depressed, the KEYIN voltages should all get pulled up to a solid 3.3V.
Q3 is an electrical "switch" that should only pull collector of Q3 to ground (~0.2V) like a pushbutton when the PWRTRIG signal is asserted to turn on Q3.
The STBY net s.b. pulled up to 5V b/c it's tied to the NS5V on the A/V/Psupply board. This pushbutton similarly grounds the STBY net when depressed, and should drive the U6 low when asserted.
That U6 device is I'm sure a custom programmed PAL that's interpreting all of this I/O and taking action on it.
U6 P2 0 and 1 are probably OK as you're measuring ~2.5V w/ the DMM. That's the clock for U6 so it should measure middle of the road w/ a DMM. Checking it w/ a scope would be better.
Is the PWROUT signal going high when the STBY PB is depressed?
That PWRTRIG signal at U6-17 wandering all over may be an issue. That should be set at one state or the other based on the logic of U6. It should probably be low by default based on the fact that R33 is trying to pull the net at Q3-2(base) down. That turns Q3 off so it's not pulling the KEYIN2 net down. PWRTRIG should only go high when driven high by U6. I'd definitely check Q3 to see if it's OK. KEYIN2 (and Q3-3) should rise to 3.3V when no key depressions or IR/Power control is trying to power the unit. If Q3 is OK, you might try isolating Q3 from PWRTRIG by pulling R35 just to see if Q3 shuts off properly (which should make Q3-3 rise to 3.3).
Fun stuff.
Fun Stuff is right!
I’m going to have to read through your post 20-30 times to absorb what you wrote.
U6 is custom programmed by (or for) McIntosh..I think I read that in the service manual.
I’ll dig in tomorrow (wine + electronics = iffy), and report back.
Thanks again for the in-depth explanations, and taking the time to help.
Been tied up with kids and sports, so no time to mess with voltages over the last couple of days. This weekend I’ll have some spare time. Gotta strike while the iron’s hot.
Well, here we are at the end of October 2025...the McPaperweight is back in sight. I moved on to a couple of tube amp projects, turntables, then other hobbies, and now back again. I have been using an old Denon 5-disc player from my college days, so there has been no urgency to get this issue solved.
I'm going to open it up tonight to reacquaint myself with the innards and continue on where I left off.
