macman007
Mcintosh..Made In USA
Yesterday while listening in Pure Stereo my Subwoofer outputs abruptly stopped working. There is only a little output at full volume/bass/loudness/sub gain, almost like a popping and vibration timed with the bass notes. I tried all positions for Music/Cinema/External, same thing, but a bit louder than Pure Stereo. I have 1 PS-112 and 1 XLS 112 and switched them in and out between balanced and unbalanced outputs same issue. I also tried a third Velodyne sub, same issue. All other balanced and unbalanced speaker outputs in A and B work fine, both in and outs.
Every other balanced in and out work fine for every other component. I have been thru the entire menu setting and option with no success I was running in Pure Stereo, with XLS 320's and XLS 112 listening to my turntable. All other digital and analog inputs when selected have the same issue. I tried different speakers and amps/speaker cables/interconnects/sources, everything, ..no dice..
I tried a factory reset, tried changing the crossover frequency in the OS menu, large, small speaker settings, gain, MC Bass on and off, different crossover points, same issue. All 3 subs work fine on a different preamp. I checked the balanced and unbalanced interconnects and swapped in known good ones in all positions, same issue. Other than the Subwoofer outputs everything works fine for now.
I bought the unit brand new in 2005 From my local Certified McIntosh dealer, and it has been babied all it's life. I even tried a light DeOxit treatment with pipe cleaners on the balance and unbalanced connectors, on the off chance I had a dirty connection,.. no go. This unit has been phenomenal since day one and is the hub of my analog and digital system, without it I'm dead in the water unless I want to hook up my big XRT's which I have no room for currently.
I do my own work on My Mc gear and for others as well, plus other audio gear as a side gig now. Mostly older gear as the newer stuff has proved to be very reliable and trouble free. I have signal generators, scope, meters counters and all manner of test equipment, but this unit is MINE and it's much more modern than what I am used to. I don't mind going inside at all. I've never had to on this unit or my MC501's, Mc Dac, transports, servers, and so on, so it's a bit unsettling to have a reasonably new unit act up like this. I know these are very complicated, so I was hoping either this was a common issue, or to get a starting point, something to start on.
Any and all help is and will be greatly appreciated. I know much of the electronics inside these newer pre-amps are sealed relays and chip driven, I'm praying it is something that wont require a trip to the local service center or Binghampton, as I'm retired and on disability now, which is why I do my own work and work for others as well, to provide a much needed income....
Thanks to all.
Thanks to all.
