Good question about the O'netics, I know that Bud and many of his audiophile pals have moved away from SET to PP triode amps, so I'm not sure that he is even making SE transformers.
Thanks, But no PP for me I'm a SET man. Even a good PP after awhile will bore me to tears harmonically. BTW remember the 100 ohm resistor comment I made and you commented on the sound being more dynamic because of the 15VDC raising of the B+? Well, I conducted a test with another very experienced musican-listener-Audiophile. And I will be writing on the subject of what we found probably in my power supply thread.
As I saw it posted on another forum a guy said Plitrons were used on the best tube amp he ever listened to, very extended. He also said " I would u$e them if I wa$ building one of Tho$e amp$ !! I thought that was funny.
Guess they have to be heard as opinions do vary :yes:
Was he referring to a SET or PP. :scratch2:
I got an e-mail from AKer Rage and he tried a set of SE Torrids
"I'm just about to dump the tomiko SE toroid output
transformers. I hate them. I'll put them in the junk box for a later
date, maybe some kind of parafeed amp.
...the tomikos were what I planned to use
but to thin sounding... no bass with them. (saturate EXTREMELY EASY!!!
major disappointment, lesson learned)"
Of course these are nowhere near the cost of the Plitrons but...
His comment is not the first I have heard of this, I have heard the same comment on the Plitrons in both SE and PP.
One comment that I read about Toroid PP bass is that it is very,very clean which contributes to a somewhat leaner sound. Some may prefer this some not.
One guy figured that it was the Toroid Cores not being able to handle DC well on Single-Ended Plitrons Tranny that he didn't like the low end and I wonder how they deal with the issue of no air-gap. I have heard this can be a factor even with Toroid power-transformers, with some designers refusing to use them because of ocassional DC on the mains, I even measured my mains and found none with a simple test circuit that was published on line. But I like the Toroid for mains transformers no doubt because of the low DCR's.
Myself I have had an interest in R-Core outputs and maybe C-Cores as well. I'd probably spend a $1000 on a set of C-Cores blind but not Toriods unless I heard them.
As to the 28lb Hammond 1642SE's I'm using. They have been in production for nearly 10yrs now I believe. And I have had immense satisfaction with them. Further I was well pleased when I had some James SE outputs here to compare to and the upper bandwidth of the Hammond vs the James was indistinguishable IMO. While the Hammond's foundation in the bass and lower mids just squashed the James. Both tranny's reproduced about the same stage size width and depth wise. The Hammonds at $500 are a bargin IMO and could be used with a 300B as well. AKer jdg123 was here during the listening comparison and felt the same way with ultimately wanting to use these Hammonds with a 45 amp. I know that seems incredible for just a 2 watt amp, but when your looking for everything you can get with authority these Hammond 1642SE's do the trick. Certainly not all the Hammonds are like this but I do like these for sure.
BTW I would love to hear the Plitrons in a shoot out with the Hammond 1642SE's!
You could even tell me I told so!:yes:
SET12
