Martynka
Well-Known Member
Thank's @Oldsansui441
I bought the 3800 only as an addition to the stands, but when I listened to how they sounded ... I decided to save them. On my Beovox 3800 the veneer and aluminum frames were in a worn condition, I put the new veneer completely over the old surface. I didn't remove anything, just filled the holes. The original aluminum trim, as in all Beovox, protrudes a few millimeters in front of the veneer. I put the veneer to the end of the aluminum. Now you can only see the aluminum trim on the front of the 3800 as an accent between the grill and the casing. But like you can see I change also few things under grill because it looked ugly ( like almost all Beovox without mask ). Oryginally it looks as if BeO took random speakers and covered it with a grill so that it was not visible.
Because I had to choose: my wife or all the Beovx at home
, now 3800 play at my friend's home and probably one of my 570x will go to him too.
