My attempt at a SX-680 recap list
OK this is the list that I compiled by physically looking and measuring the actual capacitors. I cross checked with markthefixers list on this thread. I did not use the schematic being I did it as a visual with the actual unit. I made my spreadsheet in a manner that would make sense to me so please don't beat me up too bad. Please let me know if there is anything that I might have overlooked.
It's a good try but for extra clarity I'd include the item designation. Eg C1, C2, Q1 etc.
Well done :thumbsup:
mtf updated list:
Pioneer Part Number Rating uF Voltage Qty Location Mouser Part #
CEANL 2R2P 50 2.2 50 6 C203, C204,C211,C212,C511,C512 647-UKL1H2R2MDDANA
CEANL R47M 50 0.47 50 2 C301,C302 598-DSF050J474
CEANL 470P 25 47 25 2 C205,C206 647-UKL1E470KEDANA
CEA 101P 10 100 10 4 C209,C210,C313,C314 647-UPW1A101MDD6
CEA 4R7P 35 4.7 35 4 C219,C122,C132,C165 647-UPW1V4R7MDD
CEA ERR 6 220 6 2 C309,C310 647-UPW0J221MED
CEA 470P 35 47 35 2 C311,C312 647-UPW1V470MED
CEANL 100P 16 10 16 2 C329, C330 647-UKL1C100MDDANA
CEA 3R3P 50 3.3 50 6 C331, C332,C333,C334,C167,C501 647-UPW1H3R3MDD
CEA 470P 16 47 16 3 C336,C125,C407 647-UPW1C470MED
CEA 470P 50 47 50 1 C335 647-UPW1H470MED
CEA 221P 6 220 6 1 C164 647-UPW0J221MED
CEA 470P 25 47 25 1 C502 647-UPW1E470MED
CEA 100P 16 10 16 2 C221,C156 647-UPW1C100MDD
CEA 331P 35 330 35 1 C405 647-UPW1V331MPD
CEA 221P 16 220 16 2 C131,143 647-UPW1C221MPD
CEA 331P 16 330 16 1 C133 647-UPW1C331MPD
CEANL 010M 50 1 50 2 C138,C141 698-DSF050J105
CEA 220P 16 22 16 1 C158 647-UPW1C220MDD
CEA 221P 63 220 63 2 C403,C404 647-UPW1J221MPD
CEA 221P 35 220 35 1 C415 647-UPW1V221MPD
CEA 221P 50 220 50 1 C406 647-UPW1H221MPD6
CEA 101P 25 100 25 1 C408 647-UPW1E101MED
CEA 2R2P 50 2.2 50 1 C416 647-UPW1H2R2MDD
CEANL 4R7P 25 4.7 25 2 C507,C508 647-UKL1H4R7KDDANA
CEA 101P 35 100 35 2 C513,C514 647-UPW1V101MPDAZHTD
CEA 010P 50 10 50 3 C124,C129,C142 647-UPW1H100MDD6
CEA R47P 50 0.47 50 2 C150,C151 598-DSF050J474
I’ve been reading this thread thoroughly as I have a 680 with no sound output. I already have most of the parts in a Mouser cart. However, there are these that I couldn’t find (the reason is in parentheses):
  • CEANL R47M 50 0.47 50 2 C301,C302 598-DSF050J474 (not available)
  • CEA 470P 16 47 16 3 C336,C125,C407 647-UPW1C470MED (not found)
  • CEA 470P 25 47 25 1 C502 647-UPW1E470MED (not found)
  • CEANL 010M 50 1 50 2 C138,C141 698-DSF050J105 (not found)
  • CEA R47P 50 0.47 50 2 C150,C151 598-DSF050J474 (not available)
  • 647-UPW1E101MED (On back order)
    Any alternatives to these??
I am just about to press send on my Digikey order to rebuild a friend’s 680. Here are my replacement for your above parts (in corresponding sequence):
  • WIMA - MKS2F034701M00KSS
  • Nichicon - UPW1H470MED1
  • WIMA - MKS0B041000F00KSC9
  • Nichicon - UPW1J101MPD6‎
Please note I buy a bunch of these caps in bulk for inventory, and will purchase the 63V version to have available for future projects, as is the case above with the above power supply caps.
I hope this helps regardless. Happy soldering.
Hey All,
The lead spacing on the original 8000uf power supply caps is 16mm and the replacements measure 10mm. My question is with such short lead length on these snap in caps how are you getting them to fit?
Thanks Steve
Looks like I answered my own question. Taking a minute and looking at the trace side of the board there are 2 optional holes filled with solder spaced 10mm apart that are on the same traces as the original capacitors with 16mm leg spacing.
