MBuras
Restoration is an Addiction
I posted here a while back that I was looking for what many considered to be the best, or their favorite, Marantz integrated amplifier. Most of the results came back either 1060 or 1200. I bought a 1060 and did an extreme rebuild on it. While I liked the general sound of it there was some oomph missing. Then I found a 1200 that needed a little help and thought what the heck. I'm in!
Although I have rebuilt probably 50-60 receivers and amps, mostly Marantz with some Pioneer, Sansui and Sony thrown in for good measure, this would be my first hands on experience with the American made Marantz models from the early 70's. And I have to say I geeked out a little on the build quality, elegant assembly, and even stunning solder work on the boards. Wow! They really knew how to build them.
So after seeing the amazing workmanship that went into this engineering feat I knew I had to do this right. No shortcuts on parts which makes things get expensive real quick. Vishay 138 AML axial capacitors all around with exceptions for out of stock values. Polypropylene films for any film capacitors replaced. I did originally think about replacing all the resistors with Vishay CMF series but the build cost went up significantly and I decided against it. Probably not enough ROI anyway.
In the posts below I'll document each board. This is only meant to be a reference for me and not a definitive guide as there are others here that are much more well versed in these models. And I'll warn here that this is not a beginner model to work on. Even with years of experience there were some moments where I had to sit back and gather my thoughts. It was challenging but fun and rewarding.
