muovimies
Somehow I've never owned a Sansui amp before, they always seemed to command too high a price on the used market compared to what you get and since they are not all that plentiful in Finland, one never came up. I never even felt particularly curious to be honest, from everything they looked just like another Japanese amplifier to me. For one reason or other I suddenly got the urge a couple weeks ago to get me some Sansui, was really drawn to a AU-505 on an auction but the price got too high, so I grabbed an AU-101. Since this was going to be used mostly for computer system nearfield, power is not an issue.
So far I like it, it's in completely original condition, it's the first version with no bias adjustment pots. Cosmetically it's a bit tatty but not too bad (by my low standards - it has one broken switch for example). The sound is quite enjoyable, I definitely prefer it to anything vintage Pioneer I've heard for example. It's sitting on top of a Pioneer SX-535 receiver and soundwise it's a no contest for these ears. The highs are surprisingly nice on this amp. It definitely leads with the bass though, which can get a bit boomy with some material and the midrange seems a bit recessed perhaps sometimes. I feel drawn to listen to electronic music and rock with it because it sounds so snappy through the frequency range.
It replaced a Yamaha A-700 in this application, which is a bit unfair comparison in a sense because the Yamaha I've completely gone over, it's 10 years younger (a lifetime when you compare solid state gear 1970 - 1980). The Yamaha is well into the low distortion era, with rated 0.005% THD, I think even less if you enable Class A mode for first 5 watts. In some ways it's a not a contest really, the Sansui can't compete in the overall cleanliness of the sound or the natural midrange the Yamaha has, but with these speakers, in this application, I think I actually prefer the Sansui. The Yamaha can sound a bit dry and combined with the full range drivers, that can be a bit much. The Sansui in comparison sounds almost euphonic, with a liquidness and satisfying weight to the sound. What surprises me about the Sansui is the highs, they are way better than I anticipated. The bass I was prepared for from reading forums and have learned over the years that an amplifiers power rating or heftiness in build doesn't directly correlate with how it presents low frequencies.
The source selector switch needed some tough love, when I first powered it up I got both channels only from the tape monitor even that switch needed fiddling to get sound, AUX gave me only the right one and phono input was synthetizing a sound on it's own... I had to resort to WD-40 for the switch, which I hate to do but have found out with bad cases of oxidation it's just way more effective than specialized contact cleaners, but you gotta flush it out with some proper cleaner or IPA or something, because it leaves a residue behind and that can be slightly conductive. Anyway, WD-40 followed by CRC precision cleaner seems to have cured it. It seems to play nice now. Yesterday at first I got some static crackle and low freq noise from the right channel, but that passed once the amp warmed up and stabilized and has been gone ever since, it's pretty quiet now. It sounded like a bad transistor, which I guess could very well be the case, but maybe it was a tired cap finding some new life after getting some juice or volume pot related.
Anyway, the AU-101 seems a rather nice little amp and since it's a rather simple design, it should be easy to sort out if anything comes up. I was planning on a recap, but I think the flying saucer transistors might be more urgent. There's still some crackle occasionally, but it might also originate from the volume pot. I think there's a reason techonology has moved away from cap coupled amps, but sometimes listening to old solid state gear from the early 70s, I wonder why
