Link doen't work for me
I've got one of these turntables in my basement, minty condition and in its original box. I plugged it in years ago, but the mechanism underneath didn't want to cooperate. You guys are making me want to dig it out and access the know-how of the impressive Lab 80 lovers on this cool thread.
Thanks for sharing the video. Did anyone notice that the unit is seriously out of adjustment? She turned it on with the auto button so the arm should have raised itself up and the unit should have shut itself off. Another thing, the cueing tab was always out. Personally, I would not clean my records by dragging that brush on a moving platter and putting the brush back face down on the table. I'm also surprised she didn't wipe the entire stylus off the cartridge. Sorry if I'm being overly picky.
Well, looking at his webpage, apparently the vid is a series of videos "Moving Images and Sounds." Has anyone hit the little + sign on the upper left corner of his screen to see his other videos? They're quite interesting. The Lab80 does make some interesting sounds.
A question: to me, "balancing" a platter refers to what Garrard did at the factory: after the final, precision machining, they spun the platter on precision balancing equipment and inserted copper weights into holes at the periphery to correct imbalances possibly caused by porosity in the alloy casting or other irregularities. What are you referring to as "balancing the turntable?"
Sorry for the late response, by "balancing", I was referring to using a bubble level to make sure that the platter is level. If the plinth/platter are not level then I think the platter binds as it revolves on the spindle, causing a speed hiccup.
), and YES, it is preferable that the unit be leveled so that the shaft the platter rotates on is perfectly level. On older record changers with unbalanced tonearms, leveling was doubly necessary: if the unit tilted one way or the other, the tonearm would tend to slide inward or outward. One could actually use this tendency as a kind of antiskate, but running the platter untrue would result.
