A status report on the Sychro-Lab motor mounts: I think I'm finally done with the development part of the job for the new design. In short: The top cap is now 0.1 mm lower and a smidgeon wider, and the bottom tip (which holds the pillars) has a more precise shape for a better grip. And I've also had to add one more type of silicone to my stock, so I can make the softer grommets a bit harder than before. I'd expect these to finally do the trick.
Now I'll have to make a new set of moulds for these, and in about one week I can start churning them out. Of course
@TechEd58 will get the first set with my apologies in due time.
One possibly interesting find from the measurement bench: I think the original grommets have two basic ways of aging. The first of course is by the rubber hardening, but I found out that one of the original sets I tested had lost part of their grip on the pillars from the motor. Because of this, the spacers didn't have any play between the E-clip and the top of the rubber grommet. Those grommets were the worst of the lot, because the only remaining isolation was the thin and hard rubber top of the grommet. A harder original set which still held the pillars at the correct height was much quieter. And my newest set was a bit (3-5 dB) quieter than the better old ones.
So, the first thing to check if you think you may need new grommets for a Synchro-Lab should be the play on the spacers under the motor mount E-clips. If there isn't any, they certainly should be replaced. If there is, new ones should be better, but possibly not dramatically so.
Unfortunately, I haven't received any new reports on the Lab 80 mounts, apart from the first ones working as expected.
