Pio1980
AK Member
I got my LAB 80 at an antique shop and it was obviously VERY lightly used.
I noticed a slight wobble in the pitch after having it for a year (not sure what took me so long to notice it...maybe it wasn't always there??). It is more noticable on the last track on a record side.
I verified the speed hiccup with a stroboscope. It appears to be once every revolution. The marks on the scope slightly drift backwards (I could live with that, if it was constant) but once a rev, they jump back as if something is rubbing.
Here is the situation:
- I have the spindle oiled with light sewing machine oil,
- I thought it was a warped platter, so I bought a second platter for cheap to test...nope...still hiccups.
- The inner rim surface (where idler contacts) was cleaned with alcohol.
- The main bearing is in excellent shape and properly assembled (i.e. the upper and lower thrust plates are where they should be, the balls are in place and the plastic bearing housing is flawless.
- The idler wheel shows no signs of cracking or hazing and I have rejuvenated it and filed off the outer surface to expose new rubber. It also gets up to speed in about 2 seconds, so that tells me the wheel is acceptable. (not that I suspect an idler wheel or motor problem because the hiccup is once per platter revolution)
I really dig this turntable. My PL-41 is in storage because I prefer the LAB 80 with Shure M91E as my daily driver. I'm just bothered knowing that the hiccup is there...I'm sure you all understand.
Any suggestions would be appreciated.
Thanks,
JD
Make sure the arm thingy the idler sits on and everything associated with allows the idler to move freely and completely when the functions and speed selectors are manipulated. Free them up with a bit of light machine oil if necessary.
