ZORK,
Where did you end up getting the hex nuts from? after seeing your acme threaded rod rack i wanted to build one but the nut price is crazy . the rods are only a few dollars more at mcmaster but the nuts are almost $2 a piece. do you have a better source?
Boy, do you have the wheels turning in my head! That's exactly the sort of rack I need to build for my equipment. Very simple, very elegant, and utterly functional. I love it.
I can see installing some LED lights routed into the bottom of each shelf to illuminate the gear faces - my eyesight is not what it used to be. I'm a drummer, so I could also see using some of the oversized rubber feet used on drum stands on the bottom of the rods.
Those inset nuts you used on the top shelf was really the finishing touch. Good job, my man.
GeeDeeEmm
rack looks great, did ya have to pay your brother for the gear?
I simply went with a aluminum server rack. I like the look.
I don't suppose you'd mind linking to the exact rods/nuts/washers you used for your rack, would you? There are so many different sizes/finishes that it is hard to know what to look for.
