My understanding is that the CA-2000 is the Japanese "domestic" version of the CA-2010, so they are the same/identical amp.Finally I own my Yamaha CA-2000 and CA-2010...
Plz correct me if I'm wrong. I have the CA-2000 (refurb'd), yes, a nice amp. I like the CA-1000 and still need to refub my A-1...
Use quality parts from a reliable source and you will be fine. Unplug/Unsolder wires from power amp modulesi will do the restoration on both amp soon
Thanks for your valuable adviceUse quality parts from a reliable source and you will be fine. Unplug/Unsolder wires from power amp modules
and remove. Also unsolder 4(?) wires on the meter board to remove front end. It's a reasonably straight forward
refurb.
Awesome job. How did you clean these boards? I might add this to the scope of work on my upcoming CA-1000 restoration.Dirty job started with the first board of CA-2000 series........
Before cleaning...
After cleaning...
Rewired with connectors...
View attachment 1533833 View attachment 1533834
I am using brush with Isopropyl alcohol (IPA) to wash away the sticky flux residue.Awesome job. How did you clean these boards? I might add this to the scope of work on my upcoming CA-1000 restoration.
That slide switch on the right needs to be disassembled and cleaned properly.
Using a KROY shrink tubing labeler?
http://www.cablemarkers.com/k5100.htm
Nice work ksteo, what do you think of the sound? You have helped the next person out with those plugs.
