J. Schaeffer
I've been working on it every night a few hours since I last posted. Ended up I did hurt something... I hadn't performed a sonic test due to the fact I was able to turn the trimmers back the amount of turns I had gone and the offset was good. Ended up that it had a 60/120 hz buzz that was consistent with the volume knob. It only occurred with an input adapter wire was connected and that input seletcted, and would disappear when an input device was connected and actually driving the amp's input. Therefore, as soon as the music started the noise disappeared. Otherwise the amplifier performance was great. Removed and replaced all solder in the amp . Did b/e voltage drop tests on all 40 or so transistors in the amp with it powered up. All units 550 to 620 mV. What the heck? Makes sense since the offset was good, right? Started testing all caps and trans out of circuit last night. All good. Resistors... all good, except the 47k resistor coupling the phono thumbscrew ground. Found it last, of course after 30 hours of work. It didn't even appear damaged but was open. I can't believe it took this long to find it. Lack of experience with this or any amp repair the likely culprit. I knew it was a ground loop because the sound, so I read, and I had 150mV ripple everywhere in any dc supply line reading ac on a meter. I back probed the headphone jack and discovered that this stray ac voltage was varying with the volume knob also.
In the meantime I have all diodes except the zeners coming tomorrow. I figured I'd do them anyway since this has become a full restoration. Was able to get the output cans out without damaging the mica wafers under them and the bd 139s. I ordered the to-3 mount pads that Leesonic has used on at least one of his amps that I know of. Also, this amp has the 6553/6556 complimentary pairs in front of the outputs. Probably routine but differs from the schematic.
Hopefully this is the only problem since I over biased the amp, and I suppose if one transistor turns on full that means they all turn on full because of overdriving the feed back loop, etc. Everything theoretically went dc and I don't think that was great for the amp. I'm glad all the original transistors are good in the amp, I suppose that's where the sonic magic is. I know nothing about tuning and matching small signal transistors and the modern replacements seem to vary on their specifications.
As far as the idle current, I certainly have it back to stock 1k and 1.2k except it's across trimmers now. Maybe I'll get brave enough to dial it in at some point the right way now that I know how.
I'll have it wrapped up by this weekend and let you guys know if it's fixed. Thank you for the wisdom so far.
Edit- I am not sure if what I said is what really happened since I don't have any real test equipment and lack long-time experience.
