Nad 3020A - balance pot.
Also, has anyone successfully removed the balance pot from the circuit whilst leaving it physically in place? This modification has probably been reported on the forum, just haven’t managed to locate it.
My power amp has separate channel volume controls so the absence of the balance function on the NAD would probably be fine.
Many thanks.
I found a dual pot on eBay that will fit, and works fine. The only snag is that it doesn't have the center detent in it like the original. It's a 20K pot with a tapped center.
By the way, is it bad practise to leave the power switch in the 'on' position and switch power on and off at the mains.
Just replaced the power switch and suppression caps and really don't want those switch contacts becoming coated with carbon any sooner than necessary!
