Both are a yes. Would it be safer to preset the trimmer while its off the PCB to lets say 0.5Komhs or is it okay to adjust it while measuring bias untill DMM reads something at all? Thanks a lot you have helped a bunch so far.0mV would mean there's no current flowing through the resistor - a couple of checks:
- is the DMM correctly set for DC mV measurement ?
- with the unit off, does the resistor measure ca. 1 Ohm ?
If both are yes, then the trimmer is probably a long way off.
