Yes indeed. Been reading up and he is the man for sure !I used to give the platter a little help at start up.
@jives11 is the man for these. Huge thread of his at vinylengine from a couple of years ago.
Good to hear from you Jives mate.
I'm glad you have no hum. It was never very loud, but they improved the ground coupling between the main bearing and the sub chassis and the arm pillar and the star earth point with minor changes. If yours has three small screws underneath for suspension leveling, its the final and ultimate version.
Yes setting up all the parameters is quite complex. I couldnt find a weight for the cartridge provided nor the compliance online , except amazon who quote 0.04kg (40g) which is I suspect the weight of the cartridge in its packaging. 5g seems about right, I weighed a Shure M75 and it was 6.
I reckon your parameters look right based on my interpretation of the Cartridge Tuning Guide, possibly the the oil damped needle at 3 ?
5g - 1.85 = 3.15 cross referenced with the curve of Q=10 ?
https://drive.google.com/file/d/1C9ZI0t9OlI1I81jz55NCMVPdICko3PR-/view?usp=sharing
Yes you are right... It was originally on 2 when I got it and adjusted to 3. So the needle is deep into the oil fluid.I'm glad you have no hum. It was never very loud, but they improved the ground coupling between the main bearing and the sub chassis and the arm pillar and the star earth point with minor changes. If yours has three small screws underneath for suspension leveling, its the final and ultimate version.
Wow, also very clever. Wonder if it works well ?Indeed, very clever design. He went on to design a tangential tracking arm on a deck, which is quite rare, at least in the UK. I know someone who has one, I hope to see it in action sometime when we are out of the current Covid19 situation
the AU-RA G1
They are very good aren't they ? One of them got me back into vinyl 8 years or so ago and for that I am eternally grateful.
If they had a weakness it's that their star earthing is a bit hit & miss. This isn't safety earthing, which they dont have, but they are almost 85% plastic, so safety earthing is not really an issue, but they can suffer small amounts of ground hum.
They revised the design and the later models are better. If you have a multimeter, and every audiophile should have one( £10 from ebay for the audiophiles Swiss Army knife). Test Resistance or simply continuity between these points:
1) the platter spindle top to the tip of the ground wire
2) the side screws in the arm pillar to the tip of the ground wire
ideally you want both of these to a) have continuity and b) ideally have a resistance lower than 10 Ohms
There are a few tricks you can do to improve this , but its the one area where they are not quite as good as other decks
Jives11,
Haven't used the turntable for a while but it now has a hum. Have checked the wire to the phono stage and it is suitable grounded.
It has a background hum now and wasn't there before. How do I get rid of that hum or what do I check and how ?
Thanks for the words of wisdom
Well hum can be caused by 3 or 4 different things and they are not necessarily mutually exclusive, so you can get a choir of hum. You mention its background, so I assume you can hear music on both channels, and perhaps the hum is only noticeable during quieter passages or when you are close to the speakers or using headphones. I ask because if the arm wiring was broken , often you get VERY loud hum and no signal through one speaker.
I assume nothing has been done to the deck i.e alterations too ? There is not much you can do but installing RCA sockets is one thing and not dressing the wiring properly can cause problems.
I think the first step is to rule out the motor as a cause, so if you turn off the deck at the wall, even unplug it, but on the amp/receiver behave as if you are playing a record i.e select phono, turn the volume up, is there hum present ?
with the motor off we are ruling out mechanical hum and EMF from the motor being picked up by the cartridge. Some cartridges such as Grado have a tendency to be susceptible to motor magnetic fields. Most of these decks in the UK seem to have had an ortofon OM series cartridge and these appear quite hum resistant.
Next, dressing the leads coming out of the deck so they are clear of any mains cables is also a good idea. The standard cables are just about OK, and I speak as a total cable sceptic. I'd keep them away from any other power wires or transformers
If you turn the deck on, does the hum increase as the arm arcs across a record i.e the cartridge gets closer to the motor ? That would suggest the cartridge is susceptible to the motor EMF ?
The hum grounding issues I alluded to are the poor electrical contact between the major metal parts in the deck (NOTE: I don't mean the the motor). If you have a multimeter , set it to continuity or the 100 range on resistance and test from various points on the deck (the tip of the platter spindle, the side screw head on the arm pillar) all the way to the tip of the ground wire. You want there to be a circuit and the resistance to be as low as possible, this will reduce hum from the arm wiring from the tone arm socket to where the thin tonearm wires meet the main black interconnect wires.
I can't recall if you have a flat or round arm model and what colour the front light is. The later RED LED models show some effort to improve electrical continuity for example metallic thrust pads in the bases of arm and main bearing wells. Also a green wire from the base of the arm pillar to the star ground point, check to see its not broken.
With the flat arm they added metal cueing handle which fastens using the same bolts that hold the cartridge. I'd suggest removing it as its not really needed if you are careful and I think it actually shorts the two signal grounds as the only insulation at that point is the Green NAD paint. The dot pattern on the arm suggests to me it was designed not to have the side lift. If you need one make one from plastic is my advice
Plenty to think about. I think some residual background hum is inevitable with these decks, its a question of getting it as low as possible
Jives11,
Nothing done to the deck, hum is low constant background hum, music from both channels is fine.
However, the hum noticeably increases if I touch the middle spindle and a a little bit more if touch the cartidge
Tonearm seems seated properly.
thanks. I think you will never gets these decks perfectly quiet as the signal wires from the cartridge to where they join screened interconnects, are not really screened at all, in contrast to a typical tonearm with a metal tube. But it's possible to get them quiet enough when listening from > 1M . Sorry to ask, but is it possible this amount of hum was always present but you have just noticed it ? It's impossible to unhear something, I know from similar experiences. I don't know if you have another cartridge to try just in case, the ortofon OM series were popular in these decks. I know Grado cartridges have a reputation for humming due to the absence of a metal screen in the cartridge body.
Do you have a simple multimeter with a resistance scale ? if not I'd urge anyone to get one, there are simple ones on ebay for < £10 and they are massively useful both with diagnosing audio problems and around the house.Most of the time I use the continuity/resistance reading to establish how good the circuit is between two points.
In this case I'd test from the tip of the spindle to the end of the ground wire, and from the metal arm pillar (the side grub screws are a good point) to both the tip of the ground wire and back to the spindle. There should be a circuit (continuity mode will buzz) and the resistance should be as low as possible. On more conventional decks with impeccable star earthing arrangements, its < 10Ohms. Here it may be more.
If the arm pillar to ground is open circuit (infinite resistance) I'd suspect that a wire has broken free which links the arm pillar to the ground point. Alternatively you can see if this is so but it means removing the arm and the top of the plinth
Check that the copper foil washer is on the spindle (upper side) and this contacts the bare metal part of the metal sub platter
the remaining things which help are quite invasive. Both the arm horizontal bearing and platter bearing are the same fitting, a black inverted-mushroom shaped bushing with brass sleeve. Its hard to tell from looking but the bearing sleeve is open at the bottom, so originally the thin platter bearing made point contact with the metal sub-chassis ! Having dismantled a number, some have a plastic disc in the bottom which acts as a thrust pad. These are about the size of this letter "o". I'd guess these might have been used to address some rumble ? Not sure, but they unfortunately insulate the spindle from the ground route. Even later metal "o"s were used and these complete that circuit, and I have seen examples of no o, plastic o and metal o. metal o was used last I think, and again improves the ground continuity from spindle to sub-chassis to star earth point to ground wire. I've tried to locate former Livotel employees to get their input, but no luck and sadly Jiri janda died back in the 90's.
