Fred Weather
Hi all,
Hope I'm in the right place.
I picked up a C375BEE integrated amp that has an issue with turning on. Spent some time on the net and found others have had the same problem but no one has posted any fix yet. Service manual is available with a Google search. If someone with experience on this amp could help, I'd be happy to pay for positive input.
When pressing the front panel power button, it clicks the standby relay, all the front panel lights flash and then immediately shuts off. I know there's a lot of NAD amps that have the 'protection mode' problem but I'm not sure this is one of them.
Things I've tried:
Disconnecting all connections to the power amp boards still kicks the standby relay off as above. But, doing that disconnects some of the protection chip circuit (IC205/upc1237)
Thermal switches on power amp boards are fine (NC).
Disconnecting connector P207B on the main board allows the standby relay to stay on but then nothing on the front panel works. I assume something downstream from that power source (80v &15v) is the culprit. Possibly a shorted power amp transistor. (can you tell I don't know what I'm doing?)
Questions:
Does IC205 only switch off the speaker relays or is it also tied to Standby Board relay RL401?
Connector P403B, is it a thermal switch in the main transformer?
I don't understand the relationship on connector 402B with thermal protect and standby to the transformer.
Thanks for any input.
Things I've tried:
Questions:
However this is a possibly because there have been a few (not NAD) AVRs across my bench that turned out to be a bad film cap in the power supply. Yes, a bad FILM cap was triggering the protection circuit. It was out of tolerance and was throwing the MPU into a tizzy. I don't recall all the details, but I stumbled upon it checking everything and when I replaced it, bingo! It was part of the stand-by section of the main AC power board in a Denon AVR. I can't remember the value, but it was something in the range of (but not sure) .047uf/250v red colored cap about "mid" physical size compared to the rest of them. It may, or may not be your issue though.
