Ylli,
I'm back, with a different problem on a different C375BEE. Wanted to say thanks again for all your input on helping us in the right direction on the last one.
So, I picked up another of these and this one won't even momentarily flash the blue front panel lights like the previous one did. When you press the front panel power button, it just goes from amber (standby) to red.
Since I have another working amp, I started comparing voltages. The standby board is working properly. I'd like to know how the 'auto-protect' circuit works, 'cause I'm leaning to it being the issue. The thermal switches on the amp boards all check the same.
Checking voltages... the bad amp is getting 73v to both of the amplifier boards (pin 1 of P209A & 210A) where the good amp is getting 55v. I think the problem is right after the two bridge rectifiers. On the working amp, BR201 output shows 127v. BR202 is 147v. (That doesn't make sense to me. Something else downstream pulling it down?) On the non working amp BR201 is 147v and BR202 is also 147v.
(Good amp)Voltages on TH201 are: pin 1=73v, pin 2=73v, pin 3=55v. TH202: pin 1 73v, pin 2 73v, pin 3 73v.
(Bad amp) Voltages on TH201 are: pin 1=73v, pin 2=73v, pin 3=73v. TH202: pin 1 73v, pin 2 73v, pin 3 73v.
The two large 2200mfd caps are in range.
I may be completely off track here but I figured maybe the auto-protect is activating due to over voltage?
Thanks for your time.
