Hi. Thanks for your reply!
How about the 15 ohm resistors (R435, R441 | R235, R241) how do these measure (ohmic value, voltage drop) and compare channel to channel?
I checked ohmic resistance of R435, R441 | R235, R241 without taking them of the board.
All measured 15.2-15.5 ohm, which is expected values as I think.
I don't want to measure voltage drops when unit is turned on. Last time I tried I burned R441
I get 0.65V voltage drop on R441 (before I burned it), this means that through Q342 I have current of 43mA.
In comparison to Q350 (transistors that don't get hot) - there I have 35mA (the idle current).
I'd check the flameproof resistors too: R406, R410 | R206, R210), if they drifted their changes could affect the other devices in the circuit.
As for these resistors I think they are OK - all of them measure from 98.5 ohm to 100.2 ohm.
Overall, you have fixed the amp (bias is under control and in spec)......what is the DC output measuring? Have you adjusted the ISC circuit?
I did not measure that DC output, but I think its OK there (measured about year ago or so).
I did not adjust the ISC circuit, I don't have the oscilloscope for this.
But I plan to do it in the future with replacing trimpots around this mechanism to better once from Bourns.
I already did such replacement for trimpots that control idle currents tuning.
I checked the spec of these diodes that control the small transistors:
D124, D125, D126, D127
D324, D325, D326, D327
They are specified in service manual as "SMD DIODE LL4148 SOD80 (VISHAY)".
I bought 20 pieces of "LL4148 - SMD-Si-Diode 100V 150mA Minimelf" for possible replacement.
The spec of them is here:
https://www.vishay.com/docs/85557/ll4148.pdf
It says there for forward current F = 5 mA (our case as I understand) it should give forward voltage from 0.620 to 0.720.
I turned the unit on and run it for some 5 minutes then measured voltage drop on all pairs:
D324-D325: 1.025V
D326-D327: 1.250V
D124-D125: 1.243V
D126-D127: 1.248V
But on diode pairs from same model that stand aside from amp section (far from heat area) I see:
D320-D321: 1.295V
D120-D121: 1.305V
From this I conclude that at least one pair of diodes is not OK: D324-D325: 1.025V.
I measured voltage on both:
D324: 0.625V
D325: 0.390V
So the bad diode here (as I think) it is D325.
The rest of diodes are working on their minimum voltage values.
Question: can I say that as time of use passes the diode forward voltage tend to decrease?
Is this correct statement?
For now I will replace the D325 and will see what will happen.
But maybe other diodes need the replacement too.
Ok, we see that D325 is not OK and it possibly explains why we have extra heating of Q142, Q144 on one channel.
But what with hot Q342, Q344 on other channel? What is the source of their extra heating? Will see.
