Nad 304
Brief short story, better here than in an own thread.
I have a
NAD 304 (1993) that had consumed relay contacts and it was replaced with new one. I also decided to recap the power amp section and some power supply caps as these were pretty out of spec as you'll see in the pictures below.
Few parts in this amp get hot, around some transistors in the signal input and in the other regulated PS next to the Phono input. So, for those who know this unit, I'd like to ask some advise...
Here, a new relay (Finder 24V - 8A) replaced the original Omron 24V - 5A that was cutting the sound pretty often.
A few caps were out of specs and were replaced with new ones. I don't have the SM - the HiFi Engine one is terribly scanned - so I just followed the cap's indication from the PCB. Here,
C309 (and C310 on right channel) is a cheap 85°C from Ltec caps, a company that seems still supplies to NAD. I'd like to know why this cap in this position suffers such loss of specs.
I could replace it with same 220uF value, but decided to use one of my few 270uF, rated 105°C and low ESR.
The regulated PS next to Phono input gets pretty hot due to the 4 transistors. Note the PCB is now darker due to that overheating. I'd like to know if those heat sinks could be replaced by something larger/thicker or they have to be like that?
The two 180 ohm 1W resistors (R917, R918) circled in the picture above were replaced by new ones rated 3W. Also here, shall I replace all the resistors and rectifiers for a more robust ones?
Finally, the audio signal input also shows darker PCB area where the transistors (2SA970GR and 2SC2240GR pairs) are. They don't get hot by touching them, so I supposed the stock 1/4W resistors could be replaced or is it a waste of time?
Few caps and Carbon Film 5% resistors that were replaced with Metal Film 1% around the signal input section. The amp is in a burn-in time (at least 48 hours), the sound is pretty good, I like it. However those parts under overheat maybe could fixed/upgraded. Thank you!
