dbxdx5
I'm working on an NAD 7225PE. I can program stations into the memory presets, but it doesn't retain them after powering off the unit. From what I can discern of the main tuner IC (TC-9147P), the memory function works through pins 41 and 42. Now in the NAD 7140, which uses the same IC, a super capacitor (C213) is employed, which makes sense. My experience is that either a super cap or a battery is typically used for something like this. However, in the 7225PE, it appears that a regular cap is used, albeit a relatively high capacitance one (C914). This seemed odd to me, but ok, it's how it came from the factory. . . .
I did go ahead and replace the original 4700uF 6.3V cap at C914 with a Nichicon UKL of the same value, since the parts list in the service manual specs "low leakage." This didn't solve the problem. Checking the voltages against the SM, I have the expected 4.9V at pins 41 and 42. I've also replaced the other electrolytic in this part of the circuit, C913, just in case it was causing the issue, but again, no change.
So I'm scratching head here. Should there actually be a super cap here?
First schematic snippet is from the 7140, and the second is from the 7225PE (what I'm working on).
