Check the voltage at VR101 and see if it matches the table below and is stable.
If it is not stable coming out of IC402 it will move the motor.
The collector Q406/Q406 outputs need to be stable through R423 to the motor.
If you say that the motor keeps moving back-forth, then Q405/Q406 may be bad or IC402 is bad.
