Hello there.
I know somebody posted this issue before, but I'm looking to gain some insight on how to resolve (if possible).
My RX-202 will power up for a split second (the tape counter lights up then turns off), then just the dB lights stay lit. Turning it off then back on does the same thing.
I replaced the voltage regulator (L78M12CV), but that didn't resolve the issue. For what it's worth, when I removed the old voltage regulator, it seemed like the solder came loose, and perhaps this was in fact the issue. Unfortunately it was not.
Before I start replacing part after part, can anyone recommend a course of action to take? Is there way to test voltage (using a multimeter) to know what it should be before and after a particular regulator? I have downloaded the service manual, but not really sure how to test what.
This deck is easily 35 years old, and has been sitting in a shelf in the basement for 20+ years. I was looking to sell it, so when I went to power it on (to see if it worked) I was bummed when it didn't power on.
Any insight would be appreciated.
Thank you.
Thank you.
