Nashville Electronics capacitors ?
Can confirm resistor problems, my Sherwood from the same era were significantly off. It wouldn't bias or center correctly until I changed a bunch.
If you're gonna replace those caps, you'd be best advised to also replace the carbon composition resistors. They're notorious for changing values over time.
Yep, just did 4 different Knight germanium transistor amplifiers from the early and mid 60s. Most of the carbon comps were way off. One unit had a channel that would drop in an out with distortion do to poor biasing by the drifting resistors. As an experiment, I kept using it and after a couple of weeks of use, the heat had dried them up and they drifted back some. That channel came back with no more issues. I went ahead and changed them all to metal film mostly and a few carbon films.
Great information on these caps! Thanks. Its also good to know about the carbon comp resistors. I enjoy working on these projects purely out of enjoyment and as great learning projects. I picked up the model 20 from a friend and even though its in great shape , I knew it had issues. Those caps may explain 1 of the issues , dropping in and out on 1 channel with distortion at times. A few forums had mentioned that the filter caps were notorious for failing on these , so a recap is the first step , then it sounds like the resistors may be next.
