I'm sure it could if you continue to put your fingers on them, but they are in a location where you would seldom if ever need to.Will the Sharpie wear off. I'd love to put a mark on some of my controls because they are hard to see in a dimly lit room. I was thinking of pieces of thin pinstriping which come on a roll.
All cleaned and fully tested as working correctly. Eventually it will get new capacitors installed along with some typical upgrades, but for now, it's a completely working stock example of what a 500-C was back in the day.
I have just a couple here.Purty! Kaspar at Stereo Rehab in Chicago has some of these doozies, but don't ask him to part with them! LOL
I think I'd love to own one, then let Kaspar go to work doing his magic. Probably knows them like his hand. You only live once.
https://stereorehab.wordpress.com/
Yeah, my sharpie is permanent, but on metal it probably can wear off easily since it can't soak in.JHS... I believe there are Sharpies or other pens that are permanent ink that won't wear off.
Naah, some of the overstock has left the building, this one will replace the 500-C currently here since it's a tad nicer, and has documentation.Steve, you're gonna need to build another rack, at the rate you're going!![]()
(3)Steve, do you still have all those 1800's?![]()
That absolutely amazes me. Weren’t most of them sold overseas? And you have 3??????? The Fisher Force is strong in this one!!
I used to have 4, but passed one on to a fellow AK member.That absolutely amazes me. Weren’t most of them sold overseas? And you have 3??????? The Fisher Force is strong in this one!!
I tried one of my other meters, and it showed they were 10 ohm. Turned out to be the test leads for some odd reason, swapped the leads and the other meter showed 10 ohm. Just goes to show you, can't take anything for granted in testing.
