Thanks MaggieMaggie! Appreciate those suggestions and I will look into all of them! Appreciate the distinction on the Min7s too!While Rat Shack sold min7 with wpc receiver, Min7 are ok if you want a small system for back ground music. I know everyone is going to howl, but unless you find the first generation Min7, the rest absolutely suck. If you want Radio Shack look on ebay and read up here about vintage Solo series ( 2, 21, 103 ) that use the Fostex FE 103, some models had a built in contour network that make them sound really good. If you have room Nova 6 speakers pop up cheap. The other option for a mini speaker is vintage ADS 200 or 300. Craigslist is full of small home studio monitors also. HTH.
Are you talking wood enclosures or plastic?Bought an Akai AA-810 for a song on Ebay but I don't have a decent pair of speakers for that low wattage output. I'm thinking about a pair of Realistic Minimus 7s. What else should I consider? I'm a budget electronics geek... I ain't got much money, but I love this stuff.
Appreciate that perspective. What do I reference to quantify which speakers are more sensitive?IMO, it would be more a matter of speaker sensitivity than power. With higher sensitivity speakers you get more bang for your watts.
If volume isn't really a factor I'd focus more on what you like for sound rather than a notion of needing to align watts.
Thanks for the suggestion. I'll look into those.whoaru99 is right on. The only thing I would add to that is look for speakers with an 8 ohm nominal impedance, or at least 6 ohms.
As for the Minimus 7 speakers, they are very good for what they are, especially if you have the matching reciever which has an EQ optimized for the 7's. I know, I have 2 pair with the matching reciever.
There perfect for my bedroom or small office with the EQ, Or as near field monitors for a desktop computer.
But IMO you would be better off with a decent pair of bookshelf speakers more along this line.
Monitor Audio MR2 Bookshelf Speakers - 75% Off retail
Loaded with a 6.5” MMP® II bass driver and 1” C-CAM® tweeter, the MR2 is an evolution of the multi-award winning BR2, tuning the considerable talents of its forerunner to a new intensity.Description:6.5” MMP®II bass/mid driver1” C-CAM® gold dome tweeterFront portedModelled on the hugely...www.canuckaudiomart.com
I'll look into those! ThanksIf you're looking for speakers on the cheap, I like the Cambridge Soundworks Model Six. Or you could pick up a pair of the Ensemble bookshelfs for almost nothing. Run them through a halfway decent subwoofer and they sound great.
Alright... always intrigued by the OHMs... never heard them before.OHM E's
Thanks for that info. No, about as big as I want my sound to get is the volume on my 30w receiver turned halfway up. This little 10w receiver will sit in my basement for when I'm working down there.I think your Akai is about 10 watts. Any speaker over 90 db efficiency will work for moderate volume in a moderate sized room. If you want BIG sound, you need speaker greater than 95 db efficiency. I can push > 95 db on 8 watts or less, but speakers that will do this will generally cost quite a bit. 10 watts on a 100 db speaker will get you concert level volume.
That's a killer suggestion! When I was a kid I had a Marantz 2215 hooked up to Imperial 6's and they sounded amazing! Really great suggestion, thank you!If you can find a pair of Marantz Imperial 6, they have a sensitivity of 93 db (1 watt, 1 kHz, 0.5 meters), so they should do pretty well with a 10W amp.
I have a pair running now and I really have to be carefull with the volume knob.
FWIW, maybe you know, but 1/2 way on the volume control is often well more than 50% power, if that's your implication.Thanks for that info. No, about as big as I want my sound to get is the volume on my 30w receiver turned halfway up. This little 10w receiver will sit in my basement for when I'm working down there.
