jellyfish182
I have been doing a few mods to an Onkyo Integra M-504 (had to replace 8 filter caps, put on banana plugs) and I would like to add an inlet so I can get a removable and larger power cord. When I wire this new inlet should I use stranded or solid core wire and what gauge? I read on a few other posts to not add a ground wire if it didn't have one originally (to prevent ground loops). I just want some good advice and direction because I've never done this before and I want to make things better, not worse. Also, what is the best way to cut out the hole as clean as possible?
Right now the stock power cord is stranded 16awg wire that goes through the chassis and directly to the board. I'm using a new 12 awg power cord that really brought my Adcom to life, so I'm excited to try it on the Onkyo too. I will be powering acoustic research 312HO speakers that are rated at 4 ohm and I want to give them all the power they want
Thanks guys for all of your assistance!
