Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
light and dark. Light (yellow) should be positive and dark (brown) should be negative. I would wait till some one who knows for sure and can confirm this or hook it that way and do a battery test to see if a positive connection moves the woofer forward.
as I mentioned you can double check this with a small battery to see which way the woofer moves if you connect the battery following the indicated polarity of the terminals the woofer should move forward if it moves backward the wiring is reversed.
