thornev
I've read back on several threads displayed when I did a Fisher forum search on "hum." Nothing with the exact same symptoms as mine. Here are the facts:
1. The hum volume in stereo mode is equal in both speakers i.e. it is centered in the stereo field.
2. The hum is present in stereo and mono modes.
3. The hum is present when AUX, PHONO and TAPE MON are selected even with no devices connected.
4. I poked around inside the chassis and did find a loose connection in the RIAA mod at tube V16. Before that the hum was significantly louder in one channel and soldering the loose connection resulted in the current facts.
5. The hum is present with no devices connected to any inputs and 2 dummy 8 ohm loads are connected to the speaker outs. The hum is present with a turntable connected to PHONO LOW.
6. The volume of the hum increases when the VOLUME is turned up.
7. The hum is not that loud with the VOLUME at 9 o'clock or lower, but at 12 o'clock the hum is quite loud. However, with headphones at low volume, the hum is annoying enough.
8. It is a 60 cps hum, not a 120 cps hum.
9. I have not tried tube swapping as I don't know which tubes might be the cause and I don't have replacements for all tubes.
10. I tried poking at various chassis components with a plastic pointer. Nothing struck me as suspect. With a multimeter attached and on volts DC, when I put the + lead near some chassis leads, the hum got louder. I don't know which leads they are.
11. The receiver is heavily modded. I can't say that the hum appeared only after any particular mod. I can't say the hum was there when I first bought the used receiver. I don't remember.
EDIT:
12. Important: I don't have the stock power & filter circuits. I have the SDS Labs power and filter board. In other words, I don't have the normal C91, C92, C97 nor C98 cap cans, nor CR6, R132, R149, C86 and a few other components that are replaced by the SDS Labs board.
After much reading I'm guessing this is a ground loop issue in the chassis - hum due to multiple ground points in the chassis. But then again I'm sure there are plenty of 500-C's with multiple ground points and no hum.
Anyone got any ideas about next steps to try? I do have a scope, a multimeter and soon will have a ST1000A signal gennie. I'm still learning to use the scope and gennie.
Thorne
PS - This was an interesting read:
https://www.americanradiohistory.com/Archive-National-Radio-News/NRN-1946-08-09.pdf
EDIT:
Thorne
