thornev
Tim... I changed the RIAA network to be connected without the PEC's, bridging terminals 2 and 3 (per Gadget's diagram which makes TAPEHEAD into a 2nd PHONO input) to where the PEC leads were connected. Doing so made the hum even less. And when I tested with the shorting plugs, the hum was the least it's been. There still is some hum, but to really hear it I have to turn the volume control way past 12 o'clock. I can turn the volume to maximum and the hum is not obtrusive and would certainly be drowned out by most music (turning up the volume that much would surely cause me to lose what hearing I have left!). Combining all this with shortening the leads on the RIAA networks has reduced the hum significantly. I'm pleased.
Since I was on a roll I decided to try replacing C35 and C36 (1000pF) with 2200pF which in theory is supposed to boost deep bass frequencies. It does although it seems that higher frequencies have been affected or maybe it's the phasing angles that are affected. The result is not displeasing though and I plan to leave it until some day when I become adept at using a scope to test the amplitude across the frequency range to see how the 2200pF's have affected the frequency range.
