Hi All:
Listen, I know this is a topic that has been beaten to death, and I have read much about the subject, but I would love an answer in very Simple terms, as I just cannot seem to find the answer to my question.
Ok, Ill explain. I have an AT-LP120XUSB TT. It came with the AT-VM95E. Cart was already pre-mounted on headshell. Used the online protractor that they suggested on their website to make sure everything lined up. All was perfect
Now, I am about to install another cartridge. This will be my first time. I ordered another AT cart on already mounted on the headshell. AT tech support told me that cart is set at 15.5mm overhang, and my TT required 16mm, so I am going to have to do some fiddling. My question is do different protractors use different overhangs???? This is where I always get confused. I am not worried about the terminology, cause to me it doesnt matter. MY main concern is getting the overhang correct. Ill show two examples of protractors, and that might help you answer the question easier.
OK. Here is protractor 1 This is the one that AT has on their site for my turntable. I believe it is a Stevenson. Here is the link : 0406_2904_00_cartridge_headshell_alignment_sheet.pdf (audio-technica.com)
Here is Protractor 2. This is a custom protractor made for my and other model AT TT's. As you can see it has a 16mm overhang. Amazon.com: Tracking Wizard Tonearm Cartridge Alignment Protractor Compatible with Audio-Technica AT-LP120 & AT-LP140 Turntables : Electronics
SO after all this, do different protractors have different overhangs (as I know there are others, Baldwin, Universal) or is it once you line your stylus tip on the dot, does that automatically set your overhang correctly.??? Im not so worried about the math, the numbers, I just want to make sure I am going to get my overhang correct. BTW, I hear the Stevenson is always a good one for S-Tone Arms like mine. Any info would be great
