Hi, I'm a new member in this forum. I have been reading all of your helpful responses for many years, but finally joined. I had a new Marantz 2230 when I was in college and sold it long ago.
Recently I bought a used 2252b in working condition from Goodwill and recapped the electrolytic capacitors on the P700 Main Amp and Power Supply PCB, and main filter caps. I also replaced lamps with LEDs. The amp works after this. My question is: my speaker relay is getting hot to the touch. I think I have a voltage problem at the speaker relay (L703) coil. To debug, I tried replacing relay L703 with an Omron MY4, replaced diodes Q754 & Q746, and transistors Q743, Q744, & Q745, one at a time. Made very little difference.
Measured AC input to the board at J705 is 30VAC measured with a Fluke DMM, 80VAC p-p on a scope. I de-soldered the cathode lead of the rectifier diode Q754 and measured the voltage. On the scope, it is half-wave rectified and measures slightly less than +40VAC peak as it should, so diode is working. But, when I solder it into the PCB, I measure 34VDC at the relay input with the DMM (the schematic says it should be 23VDC).
I also measured the transistor EBC and the collector of Q745 is at 0.74V vs 3.1V shown on the schematic. One other thing, C740 (soldered to back of PCB is called out in the schematic as 10uF/50V but mine was 47uF/50V soldered to trace side of PCB from Q754 cathode to ground.
Anyone have any ideas of where the problem with the relay coil voltage is (or is this normal)? Suggestions?
Thanks again everyone.
