Mat86
I have an issue with pre-amp and EQ noise on a couple setups and thought in-line RCA attenuators would be the solution to try. I'm building some cables and thought DIY'ing my own or building them into the interconnect cables would be the perfect solution. I figured either -6db or -10db might be the sweet spot, as muting is -20db and a bit overkill and I just want to lower the noise floor and compensate by boosting signal from my DAC and/or volume pot because on both I'm basically stuck at 9-o'clock
One online guide says 6.9k ohm + 4.7k ohm (to ground) would work for -10db, and another guide on youtube suggested 6.8k ohm + 4.7k as well (or 5.6k & 10k for -6db), however, a guide on the Hoffman forums says use 56k & 22k(!) and an old thread here said 47k + 47k (?)
What are the right resistor values to go with?
One amp is coming between an EQ and power-in, while the other is after the EQ in the tape loop. The second amp has a tape-input sensitivity of 150mV/47k ohm, and the EQ has an output impedance of 75ohms (stats)
