ScottFan355
Just wondering what the consensus is here for how many caps need to be replaced? Drew_t mentioned the ceramic caps, it was my understanding that these rarely fail. After caps, should I check every resistor individually? And how exactly do I go about that if so? And how about the can caps, how do I know if they've been stuffed? Going to fire up the amp in the next couple days to see if the immediate problem follows the tube or stays with the socket. If it follows the tube, how safe would you guys think the amp is to operate if retubed with EH or Tung-Sol as is? And if it stays with the socket should I first try cleaning and bending the pins a bit to eliminate a faulty contact as the problem (read where Craig at NosValves recommended that on another site). Sorry for all of the questions but I'm trying to learn as much as I can in a short time. I'm one of those unusual people that started life as a math and science whiz but then took a radically different direction and now am trying to exercise some long dormant muscles.
