d_bolle
Ok, the DBT is working fine. Upon turning the sx-550 on, the lamp glows brightly and stays bright, but the fuses don't blow anymore. So I have that important tool in my repertoire now, thanks a lot.
I went ahead and measured voltages at different points with a Fluke 87V, with the ground connected to Pin17. All voltages were at least one order of magnitude below what the circuit diagram demands:
35: 0,019
34: 0,36
33: -0,33
32: - 0,44
31: -1,143
30, 29,28,27, 0
26: 0,445V
25: -0,443V
24 23 0
21 20 19 0
16 -0,51
15 1,5
14 1.2
13 0,6
So all values were way too low. The only correct value I measured was at 38, 235V AC. Then I tried to measure around Q13 and Q14, although I didn't understand where C, B and E were. But those values were also all in the one-digit range.
So I tried again to approach the issue from the other side, and worked with the diode tester in turned off state. I measured the following:
r->b | BE | BC | CE | EB | CB | EC
Q3 | 0.70 | 0.69 | open | open | open | >3 (rising)
Q7 | open | open | 0 | 0.66 | 0.60 | 0
Q9 | 0 | 0 | 0 | 0 | 0 | 0
Q11 | 0 | 0 | 0 | 0 | 0 | 0
Q3 and Q7 look odd. Would it make sense to take them out and check them?
Again, thanks for any advice!
35: 0,019
34: 0,36
33: -0,33
32: - 0,44
31: -1,143
30, 29,28,27, 0
26: 0,445V
25: -0,443V
24 23 0
21 20 19 0
16 -0,51
15 1,5
14 1.2
13 0,6
