Soran
i made the new connections and double checked everything. the panels are in the bypass outputs and works fine. the woofers won't work at all, the only thing i hear is a 50 hz noise that gets louder when i turn the volume up. when i put the cables out there is no sound at all.
i don't get why there are 4 cables/socket in the servo and only 2 cables in the gammas. what could be wrong ?
the manual says in servo mode you could harm the speakers and amps. why ? the servo only cuts the low pass filter and the panels can handle full range.
