I've posted about this before but now that I've got a bit more experience with the turntable, I thought I'd post again
My SL-1200 (2nd hand) has a problem where after the tonearm reaches a certain place on almost every record it starts skipping backwards (repeating the same few seconds of music).
The original thought was bad bearings, but I get the sense that if it was the bearings it would be skipping all over the place. Even nasty scratched up old records will play fine for the first half of the record, but once the tonearm reaches half way, it starts skipping. This is the case for both old and new records. The odd record will make it all the way through, but they're not necessarily nice new ones. Sometimes it will skip once or twice and then play through fine once I lift the needle over the skips, but sometimes it'll keep skipping until I give up on it
If I set the tonearm weight to zero (so it floats) and blow on it, it glides... until it reaches that point, where it stops.
My theory is that perhaps the wires are getting a bit of tension on therm at a certain point, causing drag on the tonearm
Attached picture of the general area where it stops. It varies a little each time
