Need speaker id help
djeclypse
The first 3 pics look to be a fisher but do not have any identify marks or labels. The second 3 pics are epi but I cannot find any model number anywhere. Any help would be greatly appreciated.
If you pull the grill off the "EPI", that would ID them for sure. Normally, they would have a yellow sticker on the back, with the model#. Looks like yours never had it. They do look like older 100's with walnut veneer. Also, by getting the grill off, you can check the surrounds on the woofers, and make sure they're safe to use.
The grills are held on with velcro tabs in 6 spots, one in each corner and 2 mid grill. I used a 2" spackle knife. Insert it on the short side of the grill, and use a piece of cardboard to protect the wood edge. Once you get the (top or bottom) velcro to release, the rest are easy.
Here's the site to check out: http://www.humanspeakers.com/e/epimodels.htm
You could also measure the box, and compare the size.
Good Luck
That woofer looks like a Realistic 10inch from Radio Shack. It had a doped
inverted cloth surround.
