Rob_Feature
Rob Feature
Recently I've been really interested in doing conversions of different era vintage radios into bluetooth speakers. I've decided I'm going to do some for my family members this Christmas. The problem is, thus far, I'm kinda flailing around and haven't been super happy with any that I've done. There's so many factors, depending on the unit you're starting with, but I'm hoping you smart folks can help me consolidate my methods and make things work a little better.
Below is a general summary of the way I see the situation right now. There's so many factors to consider, please bear with me:
Type of Conversion
In my mind there's a couple different types of conversions:
1. "Quick and Easy" - Buy an existing bluetooth speaker, rip out the bluetooth module (which contains a small amp) and basically wire it into a gutted vintage unit (potentially re-using the units existing speaker if it works). This is the type of conversion you see all over the internet...and it's not what I want to do. This basically treats your vintage unit as an empty box that you mount a new, prebuilt, solution into. Easy but not good.
2. Bluetooth Addition to Existing Unit - This is really what I want to do and I can't find a good, basic, discussion about best practices or helpful tips. I don't really want to build my own bluetooth module if I don't have to (if that's the best way, I'm open to it, though). There's some pre-built modules on ebay that I can get for $4 that are usb powered (5v) and have line-out (which I can wire directly into, without a plug). I've used these a couple time and they have the features I want for my purposes. But:
The Power Problem
As mentioned I've found these great usb-powered bluetooth modules that are more or less ready to go. The problem? Getting 5v DC (usb) power to the unit without batteries or too many extra huge parts.
This gets more complicated because some units I want to convert are 120v AC (wall plug units) while some are battery powered (boom boxes, etc).
So...this is the biggest thing I haven't figured out: What are my simplest options/solutions for a small way to convert 120v or battery power to 5v dc? Is there a converter out there that can be used for this purpose (and i realize this is probably an either/or...there won't be a converter to use for AC and battery conversion at the same time).
Generally...this power problem is my biggest barrier...and I can't find any consistent (good) answer online on how to do it. So far, I've hard-wired an iphone wall wart into a unit, just tapping it into the AC line in....it's ugly cumbersome, and just doesn't feel safe.
What's a good efficient way to do this? Any links to converters people use for this?
The Line-In Problem
This is more minor and it differs for every unit: If you want to use the built in power amp for the vintage unit, whats the best way to locate a place to tap your bluetooth line-in into the unit? Ideally this lets you use the volume and power on the vintage unit. Is there a general rule of what to look for? (on old units, its easy to just tap into the volume knob, I've found...but most units after the 60s make this alot harder)
Ideally you'd make the bluetooth input an option (ie. you can use AM/FM/Cassette OR Bluetooth on an old boom box for example), but this is sometimes more effort than I want to put in (mounting an extra switch, figuring out where to tap in, etc). So, I'll normally find a unit where I'm ONLY going to use it for bluetooth and just bypass everything else.
Wrap Up
I know this is a big rambling post...but hoping some kind DIYers here can help me orient myself, maybe locate a part or two that will make my life easier, or offer a general roadmap on doing these conversions.
Any help out there? Thanks in advance...
PS: I grabbed a vintage wall phone that I want to turn into a bluetooth speaker for my sister (she has a vintage vibe in her basement and this on the wall would be great). I want to mount a speaker behind the dial somehow. This is just a 'gut it and use the case' project, but it should be a fun one if I can figure out how to do it
Type of Conversion
The Power Problem
The Line-In Problem
Wrap Up
