bmallett
I am a bit green to fully understanding the solid state transistors. I was able to round up the actual part numbers for the following transistors, but at $70 shipped, the 6 I needed were more than the unit's worth IMO.
Someone mentioned getting the newer equivalent transistors, but when I tried to look them up, it honestly went over my head. I'm hoping if I post the originals and their specs, one of the more educated members can help me out.
Thanks guys!
2SA640 Transistor Datasheet:
Type Designator: 2SA640
Material of transistor: Si
Polarity: PNP
Maximum collector power dissipation (Pc), W: 0.25
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 45
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.03
Maksimalna temperatura (Tj), °C: 125
Transition frequency (ft), MHz: 50
Collector capacitance (Cc), pF: 15
Forward current transfer ratio (hFE), min: 100
Noise Figure, dB: -
Package of 2SA640 transistor: TO92
MPSU06 Transistor Datasheet:
Type Designator: MPSU06
Polarity: NPN
Maximum collector power dissipation (Pc), W: 10
Maximum collector-base voltage |Ucb|, V: 80
Maximum collector-emitter voltage |Uce|, V: 80
Maximum emitter-base voltage |Ueb|, V: 4
Maximum collector current |Ic max|, A: 2
Maksimalna temperatura (Tj), °C: 150
Collector capacitance (Cc), pF: 12
Forward current transfer ratio (hFE), min: 80
Noise Figure, dB: -
Package of MPSU06 transistor: X17
2SC485 (B1) Transistor Datasheet:
Type Designator: 2SC485B
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.8
Maximum collector-base voltage |Ucb|, V: 120
Maximum collector current |Ic max|, A: 1.5
Transition frequency (ft), MHz: 10
Noise Figure, dB: -
Package of 2SC485B transistor: TO39
2SA485 (B1) Transistor Datasheet:
Type Designator: 2SA485B
Polarity: PNP
Noise Figure, dB: -
Package of 2SA485B transistor: TO39
Thanks guys!
Polarity: PNP
Noise Figure, dB: -
Polarity: NPN
Noise Figure, dB: -
Polarity: NPN
Noise Figure, dB: -
Polarity: PNP
Noise Figure, dB: -
