50 Green
Well-Known Member
Simple question (good):
Simple answer (also good):
However your reply is completely confusing:
Can some one tell me the alternative transistor part number 2SA640 ?
2SA640 is obsolete now
I think a BC560 should work. Pinout is different, check before installing. A KSA992 could work too.
Please check and compare the datasheets and application in your circuit.
elnaldo (who knows his stuff) gave you 2 viable replacement options for the one transistor you asked about (2SA640.) In your reply you bring up two entirely different transistors and ask about a replacement for the 2SA640 that is not included in elnaldo's suggestions. Keeping the conversation clear and simple will help others help you!Hi Elnaldo ✌
You mean BC560 to replace the 2SD811s ? What about the BD317 that I have replaced ? Are they compatible ? Pins meaning the 2 pins of the transistor ? They are Emitter and Base and the metal case is the Collector I believe. When I checked using my tester it shows the E, B and C. And I fit it into the slot respectively. Furthermore these large metallic transistors fit one way only. If it's wrongly fitted, the securing screws can't go in.
KSA992 is another option ?
I'm not a professional technical guy to go I to data sheets . What I do is since the original part numbers are not available, I ask the shop guy to check in their book for alternative part numbers. Can confirm in Google ✌
Can 2SA640 transistor be replaced with A1137? 2SA640 is not available either. So are the rest
