patient_ot
Well to your first comment, this phenomenon did not occur till I installed a new Cart to the tone arm. It happened to be a P-mount on an L shaped adapter with the stock head-shell.
What turntable are we talking about here? Those adapters can cause problems with some turntables. Other people have no issue with them. I generally shy away from them, personally.
The kind of level I am using is a small one with one bubble. I have used it at 4 points on the turntable and determined that it is quite leveled from all angles.
The four corners of the plinth? That is why I said check the platter itself, not just the plinth. I also would use a torpedo or long level instead.
One thing I also need to fiddle with more is the tone arm height adjustment feature. It's tricky because my apartment is lop sided (which is why I needed to level the turntable to begin with). But I will use a ruler to make sure it is proper height at both ends.
Right, since you know this, get a better level. Working with the tonearm high or cue lift is also a good idea, consult your manual on the proper adjustments.
This is the first I have heard of art protractors. Where can I purchase one for a modest price?
You can get one for basically free. Download the Conrad Hoffman arc template generator program. You will need to input your tonearm specs before printing the arc protractor. You will also need to check that it is printed to the proper scale, otherwise, no good. If you cannot print it to scale at home, take the PDF to a copy shop and have them do it for you. Once you get it right and are 100% sure it is correct, you can have it laminated or printed on cardstock to make it more durable.
