Yes the ChiFi bug can get you, it’s worse given the gear is cheap. My fascination peeked with some Tang Band D4-1 speakers and a knock off 1969 Hood class A amp. This set up sounds really really good together, the little Tang Band fours go lowwww 40Hz in the dense horn cabs.
I did a little mono block set up using a tube pre and some 3.5 inch full range drivers. Pre was $20, amps free, drivers $40. The little drivers are surprisingly good, the pre was quiet but the amps had a very loud noise floor definitely the weak point. The amps you have look exponentially better.
I have heard great things about those Nobsound amps. Those are what got me interested in class D mono amps in the first place. These are dead silent in my near-field setup. Thanks!
Just listened to the following songs I use for testing systems/new equipment. Wide range of styles and the little amps played well with all tracks.
1. L.A. Underground (Lee Ritenour & Larry Carlton) 5:48
2. Billie Jean (Michael Jackson) 4:54
3. Keith Don't Go (Nils Lofgren) 6:50
4. Thanks To You (Boz Scaggs) 6:01
5. True Love Ways (Buddy Holly) 3:00
6. Body And Soul (Diana Krall) 5:35
7. The Saga Of Harrison Crabfeathers (Brian Bromberg) 6:15
8. How's Your Mother-In-Law? (Red Norvo Quintet) 6:42
9. Welcome To The Machine (Pink Floyd) 7:31
10. Red Right Hand (Nick Cave and the Bad Seeds) 6:10
11. Tom Sawyer (Rush) 4:34
12. Go Hard (Q-Tip) 3:02
13. Know Your Enemy (Rage Against The Machine) 4:55
14. Locked Out Of Heaven (Bruno Mars) 3:53
15. Can't Stand Losing You (The Police) 2:59
@imral3 what speakers are you using with the D-Mono's? I'm thinking about getting a set to use with my FX-Audio Tube Pre-Amp and a pair of Klipsch KG 2.2's.
I read good things as well. I had to cobble together a bunch of different power supplies, all the correct voltage, but just random thrift store finds. This probably contributed to the noise.
Picked one of these up from a fellow AK’er to try out. I was pleasantly surprised. When I get sometime I am going to put it on a bench at work and checkout the components and change whatever is out of spec and see how it does.
