wwiztab
The midbass transmission tube is approx. 5 1/2" diameter cardboard and vents straight out the back. It's stuffed with fiberglass or polyfil to suit.
After reading the Phillips midbass thread from the QLS-1 database I need to verify I'm using the right midbass driver. Since this driver is ported out the back and the port is stuffed with polyfil, I assume the Phillips version I should use is the open back version. This will allow the sound from the back of the driver to come out the port, correct? I have the AD5060/W8.
