loopstick
Lunatic Member
Regular balanced dipole antennas have to be fed where the voltage is highest. Problem with this is that center fed antennas being balanced require balanced feed lines like twin lead which is what most FM receiver antennas are made of. They are often folded 300 ohm twin lead types that come with your stereos when new, you know.. the old two leg types you hang up horizontally where the lead comes down the centre.
J-poles are absolutely no different, except they are fed at the END. That means they need a means to transform the current at the end into voltage at the centre.
Minimum voltage, maximum current at the center. Vice-versa at the ends:
_________________
