I posted (Amplifier that can really roll tubes) a couple of years ago and called it the Kanas City Shuffle. Since then, I have been working on this amp on and off for two years. I tried to think of every aspect of that amp for a starting point. I was told that I should make a kt120 amp and get A-431 output transformers and I did. I then tried to think of every safety option to protect the tubes and finished that. I wanted a relay switch for the high voltage transformers T1 & T2, but it did not fit in the space. I ended up with a solar panel on / off switch for those transformers.
1. Wall socket to the switch
1. Bias supply: the EBB boards (EFB L and EFB R, on the bottom panel)
T3’s 120 V winding makes about −140 V. Each channel has its own EFB board that turns that into a steady −69.7 V of bias.
Protection: the bias follows that channel’s B+. If the wall voltage rises and B+ goes up, the bias goes more negative in step, so each KT120 stays near 90 mA instead of creeping up.
Comes up first: T3 is on the moment S3 is switched on, so the grids are biased before any B+ reaches the tubes.
2. Keep-alive board (on the bottom panel)
It keeps the ECB’s B+ sense point alive in STANDBY.
Protection: the bias is already there, a little on the safe, more negative side, when you flip S4 to OPERATE. It eases to normal in about 4 seconds, so the KT120s never start without bias.
3. Bias adjust boards (bias L and R, hanging under the plastic sheet)
Two trimmers per channel set each KT120 to 90 mA. That should read as 0.90 V across its 10 Ω cathode resistor, measured at the test jacks.
Protection: the 30 kΩ grid resistors and the separate trimmers let each tube be set on its own and balanced.
4. Fan + safety logic board (rear wall, DC only)
TRIP: it reads all four KT120 currents through 1 MΩ resistors. If any tube goes over 154 mA, or the air under the lid goes over about 60 °C, the red TRIP light comes on within about 1 second.
Bias-OK lights: the blue lights over the volume knobs are on only when both of that channel’s bias outputs are more negative than −36 V. Check them before going to OPERATE.
Why current: reading current, not just bias voltage, also catches a leaky coupling cap, a failing tube or a stopped fan. Something keeps music's peaks from tripping it.
5. Fan + safety power board (left side plate, rear, 120 V side)
On a TRIP, relay K801 opens Primary A of T1 and T2 and stays off until S3 is cycled.
What a TRIP means: Primary B keeps B+ on, so switch S4 to STANDBY, then S3 off.
It also has the isolated safety 12 V (T801), the fan 12 V supply, and fuses F701 0.5 A and F801 0.25 A.
In short:
The bias is always there first (EFB and keep-alive).
It holds steady when the wall voltage moves (EFB).
You can see it before playing (Bias-OK lights). If anything still goes wrong, the amp trips and warns you within a second (safety boards).
- J0, the IEC inlet on the rear wall. The earth pin goes straight to the chassis safety-earth bolt, never through a switch or fuse. If a live wire ever touches the case, the fault goes to earth and blows the fuse.
- F1, 5 A slow-blow, in its own holder on the rear wall. The amp draws about 2.6 A idling and 3.5 A at full power, so F1 sits about 1.4 times above full-power current. “Slow-blow” lets it ride through the turn-on surge.
- S3, the power switch, switches the LINE wire only.
- T3 (bias and preamp heaters), the small one:
- It comes on at once, through its own fuse F2 (1 A slow-blow). F1 is too big to protect a small transformer like T3, so it gets its own fuse.
- It makes the negative bias supply for the KT120s, so the bias is on the KT120 grids before any B+ can reach them. The tubes never start unbiased.
- It also feeds the heater DC board for the input tubes.
- T1 (main B+ for the KT120s) and T2 (front-end B+):
- Each toroid has two 120 V primaries, A and B, wired side by side.
- Primary B connects straight after S3, so the heaters on T1 and T2 come up at once.
- Primary A goes through the SS-12 soft start. For the first 0.1 to 0.3 s a resistor limits the current, then a relay shorts it out. Big toroidal's can draw a huge surge at switch-on; the soft start keeps it from popping F1 and stressing the rectifiers and caps.
- Primary A also runs through relay K801 on the safety board, which opens on a TRIP.
- S4 cuts the B+ right after T1’s bridge (poles 1 and 2) and after T2’s bridge (poles 3 and 4).
- With S4 on STANDBY, the heaters and bias are on but there is no B+. Give the tubes about a minute to warm, then switch to OPERATE.
- Cold tubes draw no current, so B+ would rise to about 596 V at a cold start. That’s 99% of the KT120 screen limit. Warming first keeps it at 506 V, 84% of the limit.
- The keep-alive board holds the bias reference up during STANDBY, so at OPERATE the bias is already there, a little on the safe side, and it settles in about 4 seconds.
- R130 (5 Ω) limits the charging surge into the first filter caps.
- T1’s main supply splits into separate left and right chokes and filter stages after its first filter caps, so a loud passage in one channel can’t pull the other channel’s B+ around.
- T2’s front end has a turn-on damper. Without it, its supply would overshoot to about 557 V at switch-on.
- The safety boards watch all four KT120 currents and the lid temperature.
- If a tube goes over 154 mA or the lid air goes over about 60 °C, the red TRIP light comes on and K801 opens T1 and T2’s Primary A.
- Primary B keeps them powered, so a TRIP means: switch S4 to STANDBY, then S3 off.
- Hot KT120s pull the B+ down in seconds.
- With the tubes out, the bleeders take about 2.5 minutes.
- S5, the DISCHARGE button on the rear wall, drains it to under 50 V in about 15 seconds. Push it and measure before touching anything inside.
- Switch on S3. Heaters and bias come up at once, and the soft start eases T1 and T2 on.
- Check that the blue Bias-OK lights are on.
- Wait about a minute on STANDBY, then switch S4 to OPERATE.
In short:
KT120_Rev1.6.5_FINAL_Full_Schematic_1_T1_Main_B+_and_Output_Stage_Parts.pdf433.1 KB · Views: 18
KT120_Rev1.6.5_FINAL_Full_Schematic_1_T1_Main_B+_and_Output_Stage_Schematic.pdf831.1 KB · Views: 7
KT120_Rev1.6.5_FINAL_Full_Schematic_2_T2_Front_End_Input_and_Driver_Parts.pdf649.2 KB · Views: 7
KT120_Rev1.6.5_FINAL_Full_Schematic_2_T2_Front_End_Input_and_Driver_Schematic.pdf961.3 KB · Views: 6
KT120_Rev1.6.5_FINAL_Full_Schematic_3_T3_EFB_Bias_and_Input_Heaters_Parts.pdf567.7 KB · Views: 6
KT120_Rev1.6.5_FINAL_Full_Schematic_3_T3_EFB_Bias_and_Input_Heaters_Schematic.pdf699.5 KB · Views: 6
