I have seen this issue on many of the Sansui 7070, 8080, 9090, 990, etc receivers. The "flame proof" resistors on the driver PC board just open up. They are not overloaded, they just go bad. If only certain ones go bad, you may have a protect issue, or missing sound in one channel, but if a unit has been out of service for many years, they may all be open, causing your symptom (I have seen this several times). You need to replace R33 and R34 (180 ohm 0.5 watt) on the F2624 driver PC board. I bet they are both open. You also need to replace R41, R42, R43, and R44 (150 ohm 0.5 watt) on the same PC board (I bet they are WAY out of tolerance if not open). I use metal film resistors to replace them. I usually also replace all of the other resistors of that type (greenish colored "flame proof") on the board.as I sometimes find them out of tolerance as well.
