New phono preamp from SCHIIT - the Skoll
just got to this thread and needed some advice. I have a Thorens TD1500 which I purchased yesterday. It is connected to a Mani 2 - Hegel H390- Omega Junior 8 XRS. Carts are Ortofon 2M Bronze and Cambridge Audio stock HOMC. I might end up buying a couple of more carts - but not in the near future.
Question: will the Skoll be an appreciable change over the Mani 2? If not, which other phono stage is recommended in a similar price range? I have looked at the Parasound XRM (cheaper) and also at the Project Phono Box DS3 B (more expensive). For the former not sure it be considered an upgrade over the Mani 2- and reaching out to the back to fix settings is very difficult for me. One of the reasons I don't fancy the Mani 2.
I am based in Dubai. So buying and returning if I don't like it- is not a possibility. Whatever I buy will be for keeps.
Pro-ject makes good phono boxes. The adjustments via a potentiometer and push-buttons AND on the front are so groovy!
I have the Tubed Phono Box DS2. The Raytheon 5751 tube makes this unit sound muy sabroso!
Look Of Love.
Dusty Springfield off "Casino Royale Soundtrack." Colgems Records. COSO-5005. Indianapolis pressing. 1967.
Run-out: I UZRS - - 4047 - - 3S A2
Subwoofers on. :)
I have two Schiit Skolls and love the sound quality and ease of use via their Remote Controls (no dip switches to fool around with) they are a definite improvement over the Mani.
Like Mr. Boochie, I also have a Pro-ject Tube box DS2, also very easy to use with all the buttons right on the front and it has a lot of adjustments, but I don't think they make it anymore, I believe all they have now is the Phono Box DS3 (regular and tube versions) which are quite expensive. My DS2 sounds as good as my Skolls.
The correct phono pre-amp can make a world of difference — almost as much as a good ultrasonic cleaner.
thanks. There is a Phono Box DS2 available on Pro-ject USA- I think for $499- same colour scheme as above. I wrote to Schiit asking them if getting the Skoll will be an appreciable difference over the Mani 2 and there answer (quoted below) didn't enthuse me. I am now thinking of the Phono Box S3B- has 5 pin balanced in and XLR out. Less expensive. Similar controls- though not sure how much of an improvement over the Mani 2. On another note, I have on loan a Gold Note PH-10 from the dealer I bought the TD1500. It sounds excellent (costs more too)- at the same gain sounds louder, clearer. My 18 year old daughter listened to both (both connected via XLR - Mani 2 via RCA to XLR cable)- and clearly gave the PH-10 a thumbs up. The songs was Norman xxx Rockwell by LDR.
Good morning, Manu. If you are happy with the sound you're getting from the Mani, then I would say stick with it. But if you want to try to upgrade and see if you can get a better sound, then you can try the Skoll. Especially if you plan on using the Skoll's balanced ins/outs, then that might be a reason to get it. The sound quality jump may not be massive, or it may be night and day. I don't know how your system reacts to the Mani or how it will react to the Skoll. We do have a 15-day trial period where you can experiment and see if it's worth it for you to make that jump. You'd have to pay a restocking fee, but at least you would know if it's worth it or not for you.
I went from a Mani 2 to a Skoll and found the improvement to be noticeable.
