Nyjblbob
Hooked on Horn's and Tubes. Go big or go home
No my pair of 2215bs same as Le15b crosses over at 800 cps but not to Le85’s to 376 2” Drivers. But I have used them quite successfully with Le85’s as wellBob, you are crossing the LE15B to the LE85 at 1kHz with the H92 horns correct? Have you recapped the other networks you recommended, or did you swap them in as is?
I'm looking at the schematics for those two that you mentioned, but I have also been looking for an excuse to play with a MiniDSP, so I may just tweak around with one of those and a spare amp to see where I think they sound the best before building anything.
First, I'll spend 20 bucks on capacitors and get the LX16A crossovers working as intended before going much further. Future upgrades are only a woofer removal away, but things are only original once.
The Cloth edge woofers come up to 800 cps
Far better than the foam edge woofers.
The Short L200 Horns will go to 800 cps
Although not as good as the slightly longer L300s I think it’s the H93 Horns
