Looks like you did a great job, Mr Y! Must be a very satisfying feeling. That DDX is truly yours now. I like how you handled the feet — looks great, and works better than the originals. It's a great table — sounds good, looks fantastic, and the multi-arm capability is very useful if you use MM and MC, and Mono — or any other combinations. I once had 3 arms on mine: Linn Ittok, SME 3009, and Mayware Formula 4, a range of effective-masses suited for just about every cartridge in the world.
I have the DQX 1000, the next iteration. I got in 1998, after it stood in its box in a climate-controlled warehouse, unused, for 15 years. Since then, I've only put about 2 years on it. I like to think, being almost "new", it doesn't need cap replacement. They all look good, but I know caps can deteriorate even if idle. The feet are totally effed despite so little use (just from air pollutants I guess, or bad chemistry to start with) and must be replaced. Your solution is ingenious, and a happy coincidence the Vibrapod's diameter is perfect.
Which model Vibrapod did you use, in regard to weight bearing? I'll just follow your example.
A small aesthetic note — I took the white plastic sleeve off the strobe. The table is a beautiful statement in finely tooled metal, and I find that one cheap plasticky element out of place. The strobe works fine without it and looks much better, to my eyes, consistent with the all-metal statement. As you know, you can easily try it by unscrewing the top cap — and easily replace it if you disagree with me.
Armboards are expensive and hard to find. I made some from wood — hardwoods, like oak, maple, walnut. They work just as well as the MS boards. And you have more versatility, to suit tonearms MS didn't cater for — after all, many quality arms have been introduced since MS made their limited range 30 years ago. A 30mm hole-driller from the hardware store ($8), used for installing locks in doors, is the perfect size for mounting on the post. For the rest, you can duplicate the MS boards, or get creative.
Also, a guy in Italy is making boards out of thick acrylic or aluminum, to any dimensions you specify, for far le$$ than the old originals cost. They're CNC, very precise, and the Acrylic looks quite stunning. He was advertising on Ebay, but seems to have stopped. I'll try to find his contact details if you're interested.
Meanwhile, enjoy the well-deserved fruits of your labor. And you've inspired me: I also have a Denon DP80, their penultimate DD, and now I may finally do the re-cap I've been putting off...
